Is it water or coolant
2003 VAUXHALL ZAFIRA
202,735 MILES • 1.8L • 4 CYL • FWD • MANUAL
MICHAEL FINNEY
How do I change it?
May 14, 2016 at 4:31 AM
CARADIODOC
  • 34,381 POSTS
What are you trying to do? Are you doing general maintenance and want to replace the coolant, (which is 50 percent antifreeze and 50 percent water)?
May 14, 2016 at 4:37 AM
MICHAEL FINNEY
Do I use coolant with antifreeze.
May 14, 2016 at 4:40 AM
MICHAEL FINNEY
CARADIODOC
  • 34,381 POSTS
My recommendation depends on if you are doing scheduled maintenance, following up after a repair, or you are trying to solve a problem. You want to end up with 50 percent antifreeze and 50 percent water, but how you get to that depends on why you are doing this.
May 14, 2016 at 4:45 AM
