Is it a relay or a fuse
224,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAULCEGS
My daughter is driving the car listed above. It runs great, but I am starting to notice a few electrical issues. Every time she uses her turn signals, the hazard lights flash, of course she tells me at 10:30 at night, instead of when she got home from school. I checked the fuse for the hazards, but could not find fuses for the turn signals. Could this be a relay issue with the turn signals or in the hazard relay? Also, I cannot find a diagram in the owner's manual that demonstrates the location of the turn signal relay. Any help would be appreciated.
Mar 8, 2017 at 11:07 AM
HMAC300
  • 48,601 POSTS
there is a relay behind left kick panel, but that is probably not your problem. make sure hazard switch is not on first. then check battery to body ground and ground at taillights which is in trunk area. it is a white/black wire. then check to see if it is a multi function switch problem as it may be. it can also be the hazard switch. green/black is for left side and green/yellow is for right.
Mar 8, 2017 at 10:05 PM
