2004 International Truck s engine dying
2004 INTERNATIONAL TRUCK
308,942 MILES • 6 CYL • 2WD • AUTOMATIC
SCHOOLFIELD
my 2004 international 4300 with a 466dt is dying going down the road as if the fuel filter is clogged but after changing the filter and the rock filter and priming the fuel system it still dies going down the road. what could this be?
May 10, 2010 at 2:32 PM
VEGASFARMKID
  • 30 POSTS
if you are still having this issue...If you have a NON-EGR DT466E
Check or replace the CAMP sensor. If you have an EGR DT466
Get a code from the dash cluster read out first. Have to start there.
Jun 12, 2010 at 8:48 AM
