I need to know how to adjust the fuel input into the carb. It gets way to much fuel and its causing it to choke out. When It shift it into Drive it stalls out. I have to keep it on a higher idle because if a run it at a normal idle it will cut off after a few minutes.
Aug 6, 2010 at 3:32 PM
