Intermittent starter issue
SPENCENVICKIE
  • 29 POSTS
On my 2004 Dodge Neon, I'm having intermittent starter issues. Battery and alternator check out fine, but sometimes it doesn't start on the first crank. What would the likely culprit be and the easiest to check? The starter, starter relay or ignition switch are my thoughts.
May 24, 2013 at 1:11 PM
CARADIODOC
  • 34,414 POSTS
Intermittent no-crank with a single rather loud clunk from the starter each time you turned the ignition switch to "crank" used to be a real common problem with the little silver Nippensenso starters but you have a Bosch starter with a separate solenoid on top. They don't have as many problems but I'd still start with the solenoid as the main suspect. Measure the voltage on the large battery cable terminal on the starter. I prefer to use a clip lead on the positive meter lead so I don't have to hang onto it. You will find full battery voltage there. Watch what happens to that voltage when a helper tries to crank the engine. It is normal for it to drop to around 10 - 11 volts during cranking, but if it drops close to 0 volts when it doesn't crank, there's a bad connection on that cable. If it stays near 12 volts when it doesn't crank, have the helper keep the ignition switch in the "crank" position, then measure the voltage on the other large terminal on the starter. If that one is real low while the first one is high, the solenoid has worn contacts. That problem will get progressively worse over a few months.
May 24, 2013 at 1:39 PM
SPENCENVICKIE
  • 29 POSTS
Thanks, I'll check that.
May 24, 2013 at 2:15 PM
