The problem is the solder joint that holds the fuel pump relay on the mother circuit board in the fuse box has cracked and the contact has become intermittent. The relay has overheated and has melted on one corner. Ford designed the five relays on the circuit board to be non-serviceable and recommends replacing the entire fuse box. That will solve the problem. Price on the new box is just under $500.00 and about $200.00 to install it. If you are even a little handy with a soldering iron you can do this repair for under $15.00 which is the cost of the new relay on e-bay. There are videos that will guide you along. I did this job about two months ago and have had no further problems. This is the answer, not just a guess. Good Luck
SPONSORED LINKS
Saturday, December 16th, 2017 AT 5:03 PM
