Intermittent heat?
220,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
TOOLMANTIM99
Sometimes heated air is blown, sometimes just cold air. Restarting the engine sometimes corrects the problem for that trip. After the engine turned off, lots of gurgling sounds behind the speedometer. This has worked fine for several years; the problem is only recently. When heat does come out, left and right-side temperature control sliders work okay. I have read of a valve that turns hot water off during A/C use but can't find it. Maybe vacuum activated? (The car had the A/C compressor removed before I owned it.)
Nov 4, 2022 at 12:40 AM
  • 55,694 POSTS
The gurgling sound could be the clue that the engine coolant level is low, or you have a blown head gasket that is filling the cooling system with exhaust gases which does not work for heating the heater core. When the engine is cold check the level inside the radiator.
This video and guide can help us:
https://youtu.be/GSE9skKnOgY
and
https://www.2carpros.com/articles/car-heater-not-working
This guide may help as well:
Please go over these guides and report back.
Nov 4, 2022 at 6:03 AM
