Intake manifold problem
74,500 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JEBUSHNIKOV
Hey, W211 E350 '06 with M272 V6 7G, 120k km mileage (74,5k miles). The lever on the intake manifold has recently broken (swirl flaps), so I bought an aluminum one and replaced it. Before and after replacement while trying to move instead of smoothly take off car goes on 4,000 to 5,000 RPM's, then jerks (just like quick release of clutch). Same happens while driving, doesn't matter on which gear it goes or how fast you driving. Sometimes the replaced lever got stuck in the closed position. The power drop is also noticeable.
Jul 31, 2019 at 1:07 AM
  • 55,711 POSTS
Does it feel like the transmission or the engine that is causing the problem? lets run the codes to see what comes up. here is a guide:
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Aug 1, 2019 at 9:34 AM
