Intake air system leak
122,780 MILES • 4 CYL • 2WD
KELLY ROGERS
Code p2279 and check engine light is on. what is the average cost for repair?
Jun 27, 2017 at 9:13 AM
  • 31,937 POSTS
There can be a number of causes for this problem,so to be able to give you some idea we need to know where the air leak is, the problem will be on the induction side, you can try spraying a little brake clean around the gaskets and induction pipes, if the revs alter you will have a leak, if you can pin point the problem a little closes, we can give you a better idea on what is involved in the repairs.
Jun 29, 2017 at 9:05 PM
KELLY ROGERS
I have no idea how to do that. Nor do I know what is what under the hood...thanx
Jun 30, 2017 at 4:50 AM
  • 55,770 POSTS
Sure, have a guide right here that explains it
and video
https://youtu.be/xN5pcM-5bso
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 2, 2017 at 12:54 PM
