Instrument cluster stops working when stopping?
2007 CADILLAC ESCALADE ESV
134,000 MILES • 6.2L • V6 • AUTOMATIC
JAREDA13
When coming to a complete stop while driving my instrument cluster, radio, and turn signals all shut off for a few seconds or until I start driving again. I've cleaned the battery terminals and replaced all the fuses just to be sure it wasn't causing the problem but it's still happening. Also, the brake pedal isn't pinching or touching anything it should when pressed down. What could be causing this?
Sep 16, 2022 at 9:58 AM
MIKE H R
  • 3,094 POSTS
only working sometimes then yes this is most likely a short. However, the issue is most likely on the circuit board of the cluster so having seen this a number of times. I had to change the one in our Ford F 150 because of the circuit board.
Sep 17, 2022 at 1:08 AM
  • 110,240 POSTS
I noticed we haven't heard from you for a few days. Have you been able to make any progress? I'm interested in knowing if you were able to get the issue resolved.
Sep 19, 2022 at 11:29 AM
