Instrument cluster speedometer lights
2004 BUICK RENDEZVOUS
180,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
MONEYSAM83
  • 32 POSTS
Okay, i checked every single fuse and they are all good, now the gauges work, the only problem is the lights for the gauges are not on. all the warning lights illuminate; check engine light, cruise, battery etc. I just want to know if there is a bulb in it if so can i change it out?
Sep 17, 2017 at 12:40 AM
JIS001
  • CERTIFIED EXPERT
  • 3,412 POSTS
Yes there should be bulbs you can replace. You would need to remove the cluster.
Sep 17, 2017 at 1:56 PM
