Instrument cluster does not work
2001 LINCOLN TOWN CAR
190,000 MILES
KEVIN W. MOSELEY
I bought the car listed above and the speedometer did not work. With the old cluster it will crank and run but no readings and no speedometer. I tried to change the cluster out and the car will not crank. Is there a way that is inexpensive to reset the cluster or relearn the new cluster? Hence the phrase inexpensive!
Dec 8, 2016 at 4:10 PM
HMAC300
  • 48,601 POSTS
Sorry, a mechanic has to program it to your car you can try resetting security system might start. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 8, 2016 at 10:33 PM
