Good morning,
The first thing that needs to be determined is if the engine is ready or assembled for adding a turbo. Inside the engine, you need to have a steel crankshaft and different pistons. The compression ratio needs to be around 9.5 or below.
It is not just as easy to add a turbo and life goes on. You may end up damaging the motor if you do not do it correctly.
What engine do you currently have in the car so I can check to see if your engine can handle it?
Apr 14, 2020 at 8:49 PM
