Installing a 700r4?
100,000 MILES • V8 • 2WD • AUTOMATIC
SUCCESS50
Good morning, guys, great video on installing/measuring a custom driveshaft. My question is this, we are installing a 700r4 and removing the 2-speed super turbine. We have a 326 engine. After installing the new transmission and measuring for the new drives haft length, in the video, the new drive shaft was bottomed out in the rear however when bolting it up to the front it had moved out the 3/4". Once the car is lowered on the ground will it bottom back out again? Silly question but just curious and want to make sure when I measure/install mine. Thanks guys. Sincerely, Larry
Apr 7, 2024 at 7:00 PM
STEVE W.
  • 15,367 POSTS
Once the suspension compresses it will move back in. Generally, when I measure for a shaft I try to compress the suspension, measure, then jack it up to maximum droop and measure and then measure it at normal ride height. That way you know the front yoke will not bottom out nor will it fall out.
Apr 8, 2024 at 2:52 AM
