Inner vehicle communication?
2020 MERCEDES BENZ VITO
47,000 MILES • 2.0L • 2WD • AUTOMATIC
ALEXANDROS KASTANIDIS
I want to be able to use the microphone of my car to talk to the speakers so people in the back can hear and not yell all the time.
Apr 12, 2023 at 9:43 AM
  • CERTIFIED EXPERT
  • 53,855 POSTS
To use the microphone in your 2020 Mercedes-Benz Vito to talk through the speakers, you will need to make sure that the audio system is set up correctly. Here are the steps you can follow:
Turn on the audio system: Start by turning on the audio system in your Vito. Make sure that the volume is turned up and that the speakers are working properly.
Check the microphone: Locate the microphone in your car. In the Vito, the microphone is typically located near the overhead console or the rearview mirror. Make sure that the microphone is not obstructed and that it is working properly.
Select the correct audio source: Depending on the audio system in your Vito, you may need to select the correct audio source to use the microphone. Look for an option in the audio system that allows you to select the microphone as the audio input.
Test the microphone: Speak into the microphone and test to see if your voice is coming through the speakers. You may need to adjust the volume or the audio settings to get the best sound quality.
Use the microphone to talk to passengers: Once the microphone is set up and working properly, you can use it to talk to passengers in the back of the car. Speak clearly and make sure that the volume is loud enough for everyone to hear.
Overall, using the microphone in your 2020 Mercedes-Benz Vito to talk to the speakers should be a simple process. If you are having trouble getting the microphone to work or if the sound quality is poor, you may want to consult the owner's manual.
Apr 13, 2023 at 10:37 AM
