Oil Dipstick stuck on G35
1935 INFINITI
INFINITI713
I have an 2004 Infiniti G35 and the dipstick to check the oil is stuck and will not come out. My friends and I have tried pulling and yanking it out but no luck. We tried a vis grip and pliers, but it doesn't budge. You can twist it all the way around and you can feel it twisting in the shaft; but if you try to tug on it, it doesn't move not even an inch. Any ideas on how to get it out?
Aug 6, 2007 at 12:11 PM
[quote:19f8fe1d48="Infiniti713"]I have an 2004 Infiniti G35 and the dipstick to check the oil is stuck and will not come out. My friends and I have tried pulling and yanking it out but no luck. We tried a vis grip and pliers, but it doesn't budge. You can twist it all the way around and you can feel it twisting in the shaft; but if you try to tug on it, it doesn't move not even an inch. Any ideas on how to get it out?[/quote:19f8fe1d48]
Check the dipstick tube is it removable some are bolted.
Aug 16, 2007 at 7:08 PM
