1993 Infiniti J30 Gas Fumes When Cold
1993 INFINITI
A.JOHNSON
Lately, I have been smelling very strong gas fumes in my car. It seems to only happen when it is very cold outside. Can you give me some suggestions?
Feb 24, 2006 at 2:24 PM
PEPPERMRJ
  • 1,158 POSTS
Is the engine performing well?
How is the gas mileage?
Could be a problem with the EVAP system. It stores gas fumes in a canister and then feeds them into the engine. The system is controlled by the computer. It opens a valve thru a solenoid which puts vacuum to the canister. The canister should also have a vent valve. The gas cap is part of the system and is designed to let air in and vent pressure out if necessary. Have it checked also.
Good luck and let us know. :)
Feb 26, 2006 at 8:59 AM
PEPPERMRJ
  • 1,158 POSTS
Forgot to mention the obvious. Check all the fuel lines, fuel filter, and their connections. :oops:
Feb 26, 2006 at 9:01 AM
Suggested Repair
Check the EVAP system, including the charcoal canister, computer-controlled purge valve and solenoid, vent valve, and gas cap. Also inspect the fuel lines, fuel filter, and all fuel-line connections for leaks, and note engine performance and fuel mileage.
Conversation Summary
The owner of a 1993 Infiniti J30 with 142,000 miles reports strong gasoline fumes inside the car, mainly when it is very cold outside. The expert asks about engine performance and fuel mileage, suggests a possible EVAP system problem involving the canister, purge valve, vent valve, and gas cap, and also recommends checking the fuel lines, fuel filter, and their connections.
