1994 Infiniti J30 Headlight
1994 INFINITI
SWEETIEPIE3307
When I use my headlights, my right light goes in and out all the time. One minute both lights are on and the next minute the right headlight is out. After a few minutes it will come back on again. It does this the whole time I'm using the lights. I replaced the bulb twice, but it is still doing it.
May 20, 2007 at 7:48 AM
CHALTSTER
I have the exact same car with the exact same problem. Have you found an answer yet? I did a little trouble-shooting and found out that I have an open "hot" wire. My ground wire seems to be fine. I'm in the process of trying to get an electrical diagram so I can make a jumper to get it working correctly.
Aug 6, 2007 at 1:52 PM
CHALTSTER
I discovered that the problem is a faulty Light-Control_Relay. It can be bought over the internet for around $50-$55 (it turned out to be OEM). A dealer will charge you $75. It is located under the hood on the driver's side in the corner where the firewall meets the quarter panel. It's a little tricky to replace, but if you are a little mechanically inclined, it shouldn't be too bad.
Sep 11, 2007 at 11:54 PM
BURNZEE1966
[quote:6737a3bc36="Chaltster"]I discoed that the problem is a faulty Light-Control_Relay. It can be bought over the internet for around $50-$55 (it turned out to be OEM). A dealer will charge you $75. It is located under the hood on the driver's side in the corner where the firewall meets the quarter panel. It's a little tricky to replace, but if you are a little
mainclined, it shouldn't be too bad.[/quote:6737a3bc36]
could you tell me more about were it located.
May 28, 2009 at 8:22 AM
