Transmission slips into low gear
2001 INFINITI I30
150,000 MILES • 6 CYL • FWD • AUTOMATIC
DSTRAIN
When the outside temperature is over eighty degrees and car is driven half an hour or more in stop and go traffic, instead of shifting into higher gear, it shifts back to low gear. Will stay there until I stop and turn off the engine. After engine off for about fifteen minutes and restarted transmission shifts fine, until the next time under above circumstances. It has been doing this for two summers now a total of maybe ten times it has never done in in the winter even on long trips with driving in traffic and most summer driving is limited to to and from work (ten miles one way).
Dave
Jun 19, 2010 at 4:09 AM
KHLOW2008
  • 41,814 POSTS
Hi Dave,
This sounds like you have a revolution speed sensor that is going out which may or may not set a code.
Here is a video of one being replaced and the diagrams below to show you what it will be like on your car:
https://youtu.be/f3bETtCIdxM
Cheers
Jun 22, 2010 at 1:49 AM
JOOLSSD
  • 0 POST
I had this problem as well. The sensor fixed it. I paid a shop to do it for $230.00.
Jun 13, 2018 at 8:36 AM
