I've replaced the thermostat, water pump, coolant temp sensor, head gasket and all other gaskets, had radiator flushed and when radiator is drained, it flows out nicely so I dont think there is a clog.
What could be causing this? When I repaired the head gasket, everything was cleaned. Is it possible that the new thermostat is faulty? Is there anything else that could make my car over heat. I have no coolant loss either.
Any help would be great.
SPONSORED LINKS
Tuesday, June 1st, 2010 AT 12:54 PM
