1996 Infiniti I30 P0300 code
165,000 MILES • 6 CYL • FWD • AUTOMATIC
96INFINITII30
  • 21 POSTS
Recently had the head gasket replaced and when that was done I bought new champion spark plugs and after it was put back together I am getting the P0300 code. I dont think its a bad plug because out of 6 new plugs the code would mean at least 2 of the plugs are bad.
I sprayed carb cleaner around the gaskets and on all the hoses to see if there was a leak and nothing is leaking from what I can tell.
I did notice that when my gas is around a 1/4 of a tank, the gauge seems to wander around, once it went way down past the E mark. Could this be a sign of the fuel pump going or is there something else I need to check.
I havent had any issues with coils or anything prior to this code coming on. Also I got the code P1402, the EGR valve, but was told that thats being tripped by the P0300 code?
Any Help?
Jun 4, 2010 at 9:58 AM
  • 75,988 POSTS
P0300 Random misfire is normally caused by vacuum leaks and bad fuel.
Jun 4, 2010 at 10:51 AM
96INFINITII30
  • 21 POSTS
I dont think it is a vacuum leak nor bad fuel.
When putting on the new valve cover gaskets, I did notice they were much thicker than the gaskets I pulled off.
Is it possible the gaskets thickness is limiting how far down the coils go on the plugs?
***** I read that you should only use NGK or bosch plugs with platinum tips. I have the champion platinum plugs.. would that really cause random misfires?
Jun 4, 2010 at 12:32 PM
  • 75,988 POSTS
Wrong type of plugs and improperly gapped will cause misfires
Jun 4, 2010 at 3:42 PM
