2003 Infiniti G35 check engine light
TOM POPPE
  • 2003 INFINITI G35
Electrical problem
2003 Infiniti G35 6 cyl Two Wheel Drive Automatic
when I changed the oil and air filter the check engine light came on. Not flashing but constant. I put in a k&n air filter could this cause this problem. I sprayed throttle body cleaner on butterfly (i disassembled everything first) then reset codes. It worked for 2 days then came back on.
Sunday, August 22nd, 2010 AT 8:14 PM
Check engine light on
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on
Monday, August 23rd, 2010 AT 1:08 AM
