2002 Infiniti G20 air/heater blower
2002 INFINITI G20
110,000 MILES • 4 CYL • FWD • MANUAL
KERRYKTK
  • 5 POSTS
2002 Infiniti G20 Air/heater blower
When using the air/heater fan, it makes sqeaky noises at low speed and will disappear at higher speeds. The Blower does work.
Do I need a whole blower assembly or is there a part that could be purchased and replaced to fix this irritating noise?
Also, can you help me with the directions to replace or to refer me to a How To site?
Nov 9, 2009 at 8:13 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect the motor as it is the source of the noise
located lower right side under dash
remove cover on passenger side
to gain access to it
Nov 10, 2009 at 12:51 PM
KERRYKTK
  • 5 POSTS
RE: 2002 infiniti G20 air/heater blower assembly
When you say to remove the cover, is that located behind the glove compartment? Or is it underneath the glove compartment? In other words, do I need to remove the dashboard or is it easy to gain access to the blower?
Nov 11, 2009 at 1:55 AM
BMRFIXIT
  • 19,053 POSTS
Sorry about that I should’ve been more clearer
not the dashboard but the cover under the glove box
it should be some what easy to do
Nov 11, 2009 at 8:04 AM
