1995 Infiniti G20 Adjusting the clutch.
170,000 MILES • 4 CYL • FWD • MANUAL
CLE_0109
On my g20 when I shift i have to push in the clutch about an inch for it to shift into next gear, I like it because its easier but it seems to be getting where i have to push it in less and less and I want to adjust it to the normal position. Also I cannot find my clutch resivor, does the clutch share with the master cylinder? I've heard that but haven't had it confirmed. Thanks
Mar 24, 2009 at 1:12 PM
DOCFIXIT
  • 18,828 POSTS
You may have a clutch cable. Open hood look at transaxle do you see a cable attached to lever? if yes there is the adjustment. If it is hydraulic it has a master cyl. next to brake and you adjust the push rod up on pedal
Mar 25, 2009 at 6:18 AM
CLE_0109
thanks!
Mar 29, 2009 at 7:46 AM
