1993 Infiniti G20 battery light stay on
175,650 MILES • 4 CYL • 2WD • AUTOMATIC
LUKE21660
I started my car . is started right up . the battery light came on while i was driving . i turned the car off but it would not start when i tryed to start it up after a while . i jumped the cor and it started up . i drove about a mile and the car stoped . i jumped the car again but it would not run . the car truned of when i tryed to start in . i put a new battery in the car but the battery light will not go off . the nwe battery is starting the car but the battery light will not go off . someone told me there is a fuse under the hood that will keep the battery light on but i can not fine the fuse . could you tell me how to find the fuse . could something other then this could cause this problem .
Sep 12, 2010 at 7:45 AM
LUKE21660
[quote:0c15191cd1="luke21660"]Electrical problem
1993 Infiniti G20 4 cyl Two Wheel Drive Automatic 175650 miles
I started my car . it started right up . the battery light came on while i was driving . i turned the car off but it would not start when i tryed to start it up after a while . i jumped the car and it started up . i drove about a mile and the car stoped . i jumped the car again but it would not run . the car truned of when i tryed to start in . i put a new battery in the car but the battery light will not go off . the new battery is starting the car but the battery light will not go off . someone told me there is a fuse under the hood that will keep the battery light on but i can not fine the fuse . could you tell me how to find the fuse . could something other then this cause this problem .[/quote:0c15191cd1]
Sep 12, 2010 at 7:52 AM
INFINITIANDBEYOND
I can pretty much guarantee it's the alternator, but you've probably figured that out by now.
Sep 22, 2010 at 1:15 AM
