Immobilizer bypass needed
250,000 MILES • 4.0L • 6 CYL • AWD • AUTOMATIC
JOEY1979
lost remote that disarms immobilizer. Central lock not working on the key original immobilizer. Desperate of help.
Thanks
Aug 14, 2017 at 3:26 AM
STEVE W.
  • 15,411 POSTS
The immobilizer is not a component that can be removed or bypassed as it is built into the PCM.
You either have a bad transponder antenna or bad key if the key does not work.
Try a system reset to see if the key can be made to work.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If it does not work then a trip to a dealer or locksmith to have new fobs made is about the only solution.
Aug 14, 2017 at 4:52 AM
