Information on the codes
SYMPTOM
P0455-EVAP LEAK MONITOR LARGE LEAK DETECTED
TEST NOTE
This symptom is diagnosed using the test P0442-EVAP LEAK MONITOR MEDIUM (.040) LEAK DETECTED.
WHEN MONITORED
Immediately after a cold start, with battery/ambient temperature between 4 °C (40 °F) and 32 °C (90 °F) and coolant temperature within -12 °C (10 °F) of battery/ambient.
SET CONDITION
There is a leak larger than 0.080" in the evaporative system.
POSSIBLE CAUSES
- Confirmed leak in the EVAP system
- Intermittent LDP monitor failure
Friday, April 20th, 2018 AT 4:35 AM
