Ignition switch wires
180,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
DRAMOS210
My vehicle was recently broken into and the person cut a few wires coming from the ignition switch, directly behind the steering wheel. Can i simply just splice those wires back together? I went to my local junkyard and cut an entire ignition harness just in case i need it.
Mar 7, 2021 at 12:25 AM
CARADIODOC
  • 34,414 POSTS
Yes, the wires can be spliced and soldered. You might want to check out this short video first:
https://youtu.be/4TjSYfLTHfg
First slide a piece of heat-shrink tubing onto one of the wires. Instead of twisting the wires together like we do with house wiring, I prefer to slide the two ends into each other, then press down any strands that may have stood up. Solder the splice, then slide the heat-shrink tubing over it to seal the joint. Use a needle nose pliers first to press down any strands so they don't poke through the tubing. Never use electrical tape to seal the splices as that will unravel into a gooey mess on a hot day.
Mar 7, 2021 at 2:50 AM
