Ignition switch replaced
2004 FORD FREESTAR
150,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ERIC COLSON
Lost the original key so I changed the ignition switch. That means I drilled the old switch out and had no trouble getting the new one in. But when I went to start it, nothing. All the dash warning lights work except for the odometer readout (which is a new problem. What would be causing this?
Mar 11, 2018 at 4:49 AM
Good afternoon.
The replacement key needs to be programmed.
It can be done two ways. you can take it to a dealer and have them program it or you can call a locksmith and they can come to you and program it. It takes a security license for any tech to program a Ford key.
Mar 11, 2018 at 5:31 AM
ERIC COLSON
But it just looks like a regular key.
Mar 11, 2018 at 5:50 AM
is that the key that came with the new lock cylinder? if it was, that is a skeleton key not the chip key you had.
you will need to go to the dealer or a locksmith and get a chip key cut from the skeleton key and have it programmed.
Mar 11, 2018 at 5:53 AM
