Ignition switch
211,279 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
GEORGETTE LOVE
I started my van and had to quickly turn it off and pull my key from the ignition. when I tried to restart it it would not start. I went and got a new key made still nothing. is there anything else I can do? please help
May 23, 2017 at 5:09 AM
STEVE W.
  • 15,411 POSTS
Try disconnecting both battery cables, then touch them together for thirty seconds. Now clean the connections and put them back on. It is possible the quick power on/off cycle tripped the ECM's immobilizer circuit. Try this first. If still nothing, you will need to do a bit of other checking, like going through the fuse box with a test light.
May 23, 2017 at 5:35 AM
