Car will not turn over have power when turn the key nothing?
2020 MITSUBISHI ECLIPSE
78,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
KENT KRAMER
Car will not turn over have power when turn key nothing?
Jun 6, 2023 at 5:24 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
If your 2020 Mitsubishi Eclipse is not turning over when you turn the key and you have power, there are a few possible causes for this issue:
Weak or dead battery: Even if you have power to some electrical components, the battery may not have enough power to crank the engine. Check the battery voltage using a multimeter or have it tested to ensure it has sufficient charge. If the battery is weak or dead, you may need to recharge or replace it.
Faulty starter motor: The starter motor is responsible for cranking the engine. If the starter motor is faulty or worn out, it may not engage and turn the engine over. A clicking noise or a single click when you turn the key could indicate a problem with the starter motor.
Ignition switch or ignition system issue: A malfunctioning ignition switch or a problem with the ignition system can prevent the engine from starting. Faulty ignition switch contacts or a faulty ignition coil are possible culprits.
Fuel delivery problem: If there is a problem with the fuel delivery system, such as a clogged fuel filter or a failing fuel pump, the engine may not receive enough fuel to start.
Engine immobilizer system: The engine immobilizer system is designed to prevent unauthorized starting of the vehicle. If there is an issue with the immobilizer system, it may prevent the engine from turning over.
I would go over this guide as well:
And this one too:
Please go over these guides and get back to us.
Jun 6, 2023 at 9:21 AM
