Idling issues and engine shutting off
180,820 MILES • 2.0L • 4 CYL • RWD • AUTOMATIC
REYAD SINGH
So my car listed above is the j20 model has been having idling and shutting down issues a while now. I have tried changing cam and crank sensors, servicing fuel injection system, changing plugs, regular air filter change, servicing throttle body, trying known working coil packs and using regular fuel treatments. While it has improved from shutting off constantly once at idle to shutting down only when under higher load such as on inclines or reversing, the problem is still there and the vehicle idles erratically sometimes.
Vehicle performance is high and responsive on some days while not on most days. Any suggestions?
Jul 1, 2017 at 4:23 AM
  • 55,694 POSTS
Two things come to mind for this problem, first is sounds like the catalytic converter may have fallen apart and could be clogging the exhaust system.
Here is a guide to help you confirm that.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and you should run the codes to see if anything comes up
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
Jul 3, 2017 at 6:35 AM
