HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Isuzu
Rodeo
Engine
Symptoms
Idle Erratic
First start of the day, rough idle, erratic RPMs and shuts off?
JOHN JACOBSON
MEMBER
2002 ISUZU RODEO
3.2L
6 CYL
2WD
AUTOMATIC
160,000 MILES
The rest of the day starts and runs normally. Throttle body was cleaned and PCV sensor replaced, no help.
Sunday, June 30th, 2024 AT 3:58 AM
KEN L
MASTER CERTIFIED MECHANIC
Let's run the codes first to see if any are stored, this guide will help. Also, I have seen a bad engine coolant sensor cause this issue.
This can be caused by a vacuum leak as well, use this guide when the engine is cold only:
Please go over these guides and get back to us.
SPONSORED LINKS
Sunday, June 30th, 2024 AT 10:55 AM
Please
login
or
register
to post a reply.
Related Engine Idle Erratic Content
2000 Isuzu Rodeo Question Erratic Idle, Running Rough
Vehicle Starts Ok But May Idle Erratically. When Driving At Slow Speed The Tach Shows Erratic Rpm. When You Stop At A Light Or Slow To Take...
Asked by
jim_466
1 ANSWER
2000
ISUZU RODEO
VIDEO
Vacuum Leak Test and Repair
Instructional repair video
GUIDE
Idling High
Intermittent sensor failure or shorting can cause the computer to act strange with unusual side effects, these problems are particularly tough to diagnose. The computer...
1997 Isuzu Rodeo Question Trouble After Warm Up.
After Warming Up It Seems. When You Get On The Gas The Rpms Jump Up And Down, Kinda Boggling Out. But If You Release Off The Pedal And Ease...
Asked by
Rodeo903
1997
ISUZU RODEO
Jerking While Driving
I Had My Transmission Filter Changed And Fluid Filled About 2 Weeks Ago Due To A Hard Shift Between 1st And 2nd Gear. It Fixed It Immediatly...
Asked by
kymcarroll
1998
ISUZU RODEO
My Car Wont Start
I Have A 2002 Isuzu Rodeo I Replaced The Engine Wiring Harness And Now My Car Won't Start I Though It Was My Starter So I Replaced That...
Asked by
marcusbrich
1 IMAGE
2002
ISUZU RODEO
Not Cranking Over
Turn The Key And No Crank. I Have Pulled The Starter And It Tested Good, Battery Has Been Load Tested And Good, Checked All Fuses And...
Asked by
Joncarn
2002
ISUZU RODEO
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak
Online car repair manuals
