idle high and over heat
18,000 MILES
QWERTROY
need some help here.
It is scary to drive this thing, need this fixed ASAP.
In Park and Neutral, my RPM goes up to 3900 and sits there. Happens right at start up and rpm's never go down even when engine is hot.
In Drive it goes down to 1800 and sits there.
In Drive, if I let go of the brakes the car takes off like a bat, due to unusually high rpm.
When I drive this car, my foot is constantly on the brakes! not good at all.
What is the matter with this thing?
Is it an idle issue?
A vacuum issue?
Something else?
Please help. it now over heats too.
Jan 20, 2017 at 1:26 PM
  • 55,616 POSTS
Hey Qwertroy,
This sounds like you have an idle air control motor that has failed or possible a vacuum leak. here are a couple of guides that will help you get the problem fixed.
and
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Please run some tests and get back to us.
Best, Ken
Jan 20, 2017 at 6:12 PM
