I have an 258 inline 6. It had shut off on me while driving but would start back up. I replaced the plugs and fuel pump. Also replaced the carburetor and had timing belt checked. It had jumped one tooth.
Now, it runs fine when it is first cranked. Once the engine reaches 170 degrees, the exhaust tone changes and the engine slows. If the engine is revved, it seems to behave normally. Once it cools down, it is fine again. I have replaced the coil and ignition control module thinking that the coil was failing once it got hot. Any ideas why it changes at this temperature?
Thanks,
Tony
Thanks,
Tony
Jun 1, 2019 at 1:31 PM
