Idle air control
168,000 MILES • 3.0L • V6 • MANUAL
REECCEDALTONP
My car was idling a little too high rpm so I replaced the idle air control valve myself and now when I turn the car on it revs up to 3000 rpm down to almost wanting to shut off then it goes back and forth. I do not know what I need to go back and check or if it is the new part itself.
Jul 16, 2017 at 4:34 AM
CARADIODOC
  • 34,414 POSTS
When the idle speed drops down, unplug the idle speed motor, then see what happens to engine speed. If it still surges up and down, there is a vacuum leak that is allowing in extra air.
Jul 16, 2017 at 12:35 PM
