I need a diagram of the entire fuel system
BRANDON STROUPE
  • 1987 TOYOTA PICKUP
  • 2.0L
  • 4 CYL
  • 200,000 MILES
It is not getting gas.
Sunday, February 26th, 2017 AT 5:37 AM
STEVE W.
  • 13,452 POSTS
There is not one available. Which engine do you have the 22R-E or the 22R? That will at least narrow down the testing options. Other than "it is not getting gas" can you give me a few other pieces of information? Like does the engine crank over fine? If you spray some starting fluid into it will it fire? What have you done to test the fuel system? (Pressure test, voltage to the pump, voltage to the relays that control the pump) What else does not seem to work besides the fuel system?
Sunday, February 26th, 2017 AT 7:12 AM
BRANDON STROUPE
I think 22r. When I spay starting fluid in it it will run few seconds. I am not for sure the lines are right.
Sunday, February 26th, 2017 AT 8:31 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,602 POSTS
The lines you cannot get mixed up because they are different sizes. Please test the fuel pressure and delivery.
Here is a guide that will help you though you will need to tap in by the fuel filter.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Tuesday, February 28th, 2017 AT 11:26 AM
Related General Content
