I was told I need a new transmission, but it seems fine?
136,000 MILES • TURBO • 4WD • AUTOMATIC
SERIAL85
I recently had diagnosis for transmission issue and was told I need a new transmission month ago. It's been driving normally ever since and has not been stalling or shaking.
How is it that the transmission is bad and it's still driving normally?
Could it be a transmission flush issue or another transmission issue that I can repair besides paying $4,000.00 for a new transmission.
Sep 13, 2022 at 1:35 AM
BORIS K
  • 836 POSTS
Can you please be more specific as to why the shop wanted to replace the transmission?
What issues did you encounter?
Any oil leaks? Drivability issues?
Cheers, Boris
Sep 13, 2022 at 1:58 AM
SERIAL85
The vehicle was not driving correctly, it would not turn over or accelerate.
The vehicle would stop and go while driving as make it almost impossible to drive over 40.
Two days after I left the mechanic the truck returned to normal driving.
No stalling or shaking.
The light comes on and off but driving without issues.
The mechanic said it was a transmission and needed a new one at the same but ever since it's been running fine.
If a transmission goes bad, doesn't it mean the car will no longer drive until it's repaired or replaced? but nothing was done to it but the diagnosis.
Sep 13, 2022 at 3:12 AM
BORIS K
  • 836 POSTS
I do agree that a mechanical failure in the transmission would manifest itself in driving/gearchange difficulties.
You mention that the engine light comes on and off. This means that there will be fault codes stored in the management system. Would it be possible to have a CAN scan done and then post the fault codes on here?
This would enable us to give you better advice.
How to carry out a scan:
Most auto parts stores will have an OBD-II scanner on hand to check the OBD-II PID service codes and will do it for free.
At a local auto parts store such as:
Advance Auto Parts.
AutoZone.
Napa Auto Parts.
O'Reilly Auto Parts.
Pep Boys Auto Parts.
Cheers, Boris
Sep 13, 2022 at 6:45 PM
