Could mean your low on coolant due to a leak which could be as simple as a bad radiator cap.Could be a bad thermostat or the radiator fan not working properly.Also could have sand or other debris blocking flow thru the radiator.Have you checked the coolant level or for codes?Also only check the coolant level with the engine cold.
Jun 4, 2016 at 4:31 AM
