Speedometer and odometer stopped working
1992 FORD F-150
1,700,000 MILES • 9.0L • 6 CYL • 2WD • MANUAL
MICHAEL VASQUEZ
I have the truck listed above straight 6 with a 5 speed transmission. My speedometer and digital odometer stopped working. I replaced the speed sensor on the differential and checked all fuses. Still not working.
Sep 29, 2019 at 11:51 AM
  • CERTIFIED EXPERT
  • 53,880 POSTS
I would check the instrument cluster wiring connector for corrosion, but it sounds like the speedometer module is out inside the cluster. You might need a rebuilt/used cluster. Check out the diagrams (below). Please let us know what happens.
Oct 1, 2019 at 12:20 PM
