brakes stop working from driver side
190,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
CRYJ
I got chrysler saratoga its identical with spirit my brakes stop working from driver side and same front wheel got some where playing
i like to know id there some connect whit these two problem . tie rod inner end is got some play in . some adwise for that and why same tire brake dont work ?
what i need to do .
(and dont see any where brake fluid leek )
(tie rod inner end move in like 3-5 mm ) whitout moving stearing wheel or other whell
Feb 4, 2014 at 11:25 PM
CRYJ
oh . i dosent remember tell i chanced front whell bearing 3 months ago.
Feb 4, 2014 at 11:34 PM
  • 110,248 POSTS
I don't believe the two things are related. As far as the tie rod, it just sounds worn and needs replaced. As far as the brake, that is a concern. Does the piston in the brake caliper move at all? Have you tried to bleed the caliper?
Feb 5, 2014 at 12:36 AM
CRYJ
thank you ! for answer . i don´t know much power stearing system . im realy intress to know where i can buy new stearing system (i know that can be fix buy only tie rods but im keep trying get that car beter to drive too ). but dont know much american car parts stores what sell upgrade parts.
Feb 5, 2014 at 1:14 AM
  • 110,248 POSTS
A complete steering system would be expensive. I recommend that you just replace the bad parts.
Feb 5, 2014 at 1:48 AM
CRYJ
ok . thanks (i put message when im get what is wrong brakes)
Feb 5, 2014 at 1:53 AM
