I am trying to connect a mechanical gauge to the engine Is there another place to connect the gauge to other than the hole the switch get screwed out
2002 GMC ENVOY
150,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
JMB74
Number one: local parts stores don't rent oil pressure test kits; number 2: if they did they wouldn't have the adapter that I need, an adapter bushing. The switch is 20 millimeters by two pitch on the thread. All the kits have are 1/8 npt and 1/4 npt. My question was if there was another hole to screw the guage into other than the switch hole. Try answering the question that is asked, people would find it much more acceptable than advice that doesn't apply. Thanks for an appropriate answer.
Nov 19, 2015 at 3:10 AM
