2004 Hyundai Tiburon shaking in steering wheel
2004 HYUNDAI TIBURON
55,000 MILES • 6 CYL • FWD • AUTOMATIC
CONEDOT
I've had my tires checked and I've had an alignment and my car still doesn't steer correctly. It veers slightly to the right and the steering wheel shakes at 20mph, worse at 60mph and faster when I brake. After I get up past 70mph it doesn't shake as bad. I asked a repair shop if I needed another alignment and they told me that on my type of car an alignment isn't going to do anything that there is something wrong inside...
What could be wrong and where should I take it to get fixed?
Jun 11, 2008 at 3:14 PM
WHIZKID
[quote:2056fc99bb="conedot"]Shakes or Wobbles problem
2004 Hyundai Tiburon 6 cyl Front Wheel Drive Automatic 55000 miles
What could be wrong and where should I take it to get fixed?[/quote:2056fc99bb]
Check spark plugs. if any one of them is not working, you will get low speed vibrations.. if ur engine vibrates when u turn it on then most probably a misfire is your problem..do not go anywhere, buy ur spark plugs, tubes and stuff and replce it yourself. i paid 400 bucks just to get that done ma machine..
Jun 17, 2008 at 11:31 AM
