2003 Hyundai Sonata engine stumbles
2003 HYUNDAI SONATA
37,000 MILES • 4 CYL • FWD • AUTOMATIC
JOSEPHARAGO
I have a 2003 hyndai sonata with 37000 miles. Occasionally the car will stumble while i am excellarating and the check engine light will come on and go out quickly. my local mechanic did not see any code from the computer. he says that it maybe the catalytic converter. the car does run sluggish sometimes
Oct 27, 2010 at 8:43 PM
  • CAR REPAIR CONTRIBUTOR
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 27, 2010 at 10:58 PM
