2000 Hyundai Sonata how to repair? and estimated cost?
2000 HYUNDAI SONATA
ARASH123
  • 22 POSTS
Transmission problem
2000 Hyundai Sonata 6 cyl Two Wheel Drive Automatic 75k miles
I have a car that hesitates and sometimes kicks.when accelerating mostly when the car hit 50-60km/h. The car accelerates fine when steady increasing the speed but when u take your feed off the peddle and then re-hit it acts up like i described above.
I put on computer and this what i got. Camshaft(which i knew before and never fixed it)
Main ones:
P3113
P0307
P0705
How to repair these and what is the estimated cost so i don't get ripped off.
Jul 30, 2010 at 2:06 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Would like to help but none of the codes you posted are valid to that car. What type scanner was used? can you recheck?
Let me know
Jul 30, 2010 at 3:56 AM
ARASH123
  • 22 POSTS
Here are the new codes.
p0340 Camshaft sensor
p0707
Again the camshaft code problem was on for last year or so.
New problem that started less then a week ago.
the car accelerates fine . It steadily goes up when pressing on gas. But when i left my foot and hit the gas peddle again, the car either jumps or rpm meter jumps. For example at 2000rmp then goes to 3000rpm and jumps back to 2000rmp then steady goes up.
First dealer had weird codes and he said it must be transmission but he was guessing from the drive in my opinion.
The second diagnostic tech- did not think its transmission. He drove the car and still did not think its transmission. He suspects its the cam Sensor.
What you guys think? if you need further description i will be able to explain further. My concern is if its cam senor why the car acts now when I knew about it more then year ago? The second code which is transmission range sensor I believe is new.
Thanks. Also, the dealer is charging $260 for Cam sensor part.
Aug 3, 2010 at 3:54 AM
DOCFIXIT
  • 18,828 POSTS
The 707 is PNP switch fault park neutral switch on top of trans axle that shift cable attaches. Need to remove cable so can shift with manual lever see diagram
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_547.jpg
With OHM meter check for continuity between following terminals If any fail replace switch. And Advance Auto has Cam sensor for $94 P 3&8 - 9&10 R 7&8 N 4&8 - 9&10 D 1&8 3 5&8 2 2&8 L 6&8
Aug 3, 2010 at 5:24 AM
ARASH123
  • 22 POSTS
Where is the camshaft position sensor on 2000 Hyundai Sonata GLS located? and is it easy to replace?
Aug 3, 2010 at 5:47 AM
DOCFIXIT
  • 18,828 POSTS
Piece O cake located near thermostat right rear engine one bolt pull out . May have to wiggle a bit to free O ring
Aug 3, 2010 at 6:04 AM
ARASH123
  • 22 POSTS
hello,
I had mechanics change the cam sensor. Big problem now. The engine seems to over running. it has terrible accelleration at around 25 mph. But when high speed it flies. I have never seen it with so much power. It seems like it is stock at high gear and struggling in low speeds. Whats wrong? this is new issue it seems?.
Faulty cam I installed? dont know? I am so worried.
Thanks.
Aug 13, 2010 at 2:26 PM
DOCFIXIT
  • 18,828 POSTS
Did you perform test for code P0707? what codes are present now?
Aug 14, 2010 at 4:07 AM
