1991 Hyundai Sonata fuel shut off valve
SHELLPOINT
Engine Mechanical problem
1991 Hyundai Sonata 6 cyl Front Wheel Drive Automatic
shut car off after accident, seeking reset switch location to restart engine...../
Jan 10, 2009 at 8:05 AM
THIS IS MIKE
  • 686 POSTS
Your car doesn't have a fuel cutoff switch, the fuel pump is controlled by the fuel injection relay.
start testing... go to the relay and see if it is clicking on when key is cycled. then need to see if the white/black wire at the fuel pump is getting power with key on
Use a fuel pressure tester to see if you are getting the proper fuel pressure.
Jan 16, 2009 at 6:11 AM
