2004 Hyundai Santro Fuel pressurization and tank rupture
2004 HYUNDAI SANTRO
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUDEBOB
My wifes car has been throwing a fuel system code for a few weeks. Initially, I suspected a simple gas cap replacement or hose leak somewhere. Then the gas tank started leaking. I dropped the tank and sure enough there is a ruputure type crack in a formed ridge on top top of the tank (nowhere near a contact area or area I would believe to be subject to fatigue stress).
I can fix/repair the tank but something else is happening to cause excess tank pressure (IMO). Could a faulty vapor canister valve cause the tank to build up too much pressure or is there something else I should look at?
Thanks,
Michael
Jan 10, 2010 at 11:11 PM
Plugged charcoal canister, also a liquid -vapor seperator, clogged/pinched vent lines could cause excessive pressure causing it to collapsed
Jan 11, 2010 at 1:37 AM
RUDEBOB
[quote:caf2c1e1aa="rasmataz"]Plugged charcoal canister, also a liquid -vapor seperator, clogged/pinched vent lines could cause excessive pressure causing it to collapsed[/quote:caf2c1e1aa]
Thanks for the reply. The cannister is clear and I checked for obstructions in the line. Is there any kind of venting the occurs within the system that, if it were to fail, could cause overpressurization? So far all I can find is the valve going into the vapor cannister. However, I thought this only allowed for an opening in the fuel system when the ignition is off to allow for fueling via the gas cap? Am I wrong about the function of this valve?
Any more thoughts would be appreciated.
Jan 12, 2010 at 12:46 AM
