2010 Hyundai Santa Fe Hose is leaking
154,000 MILES • 6 CYL • 4WD • AUTOMATIC
AUBREY_DAVID13
I've discovered a significant leak in the A/C line running just behind the condensor. The hose is leaking in multiple spots (from a quick look--about 15-20 different holes). All of my other hoses seem fine, but when I charged the system it lasted only about 24 hours. Green oil is also pooling directly below the leaking hose.
About 3,000mi ago I had my oil changed at a local shop. There was a major leak from the filter just a few miles after driving the car away from the store. Hot oil sprayed all over the engine covering the hose, even coming out the front through the grill and running down the bumper. The shop owner picked up the car and cleaned the engine, but I'm assuming that hot oil was in contact with this hose for at least an hour. SO...my questions is...could this oil spray have caused a sudden deterioration in this hose?
Thank you for your help,
David
Sep 9, 2010 at 11:29 AM
BMRFIXIT
  • 19,053 POSTS
Hot oil or oil should have no effect on the AC hoses and or lines
as they should be able to handle refrigerant oil that goes through them
to a very hot degrees
Sep 9, 2010 at 12:21 PM
AUBREY_DAVID13
Thank you for your previous reply.
Can you tell me...what might cause such a substantial leak all of a sudden in a hose like this? The car has 150,000+ miles and has never had an a/c line leak like this, then all of a sudden--total failure of one of the hoses and a huge loss of fluid.
Thanks again,
David
Sep 9, 2010 at 12:41 PM
BMRFIXIT
  • 19,053 POSTS
Sorry don't have an answer to that
maybe a human error or bad material
have it checked by local shop as visual check is needed to determine the reason of the failure
Sep 9, 2010 at 12:54 PM
