2007 Hyundai Santa Fe Oil filter location
JACKSTRAW
  • 2007 HYUNDAI SANTA FE
Engine Mechanical problem
2007 Hyundai Santa Fe 6 cyl Front Wheel Drive Automatic
Where is the oil filter located on a 2007 Hyundai Santa Fe? How do you change it?
Thursday, March 25th, 2010 AT 5:40 PM
  • 110,055 POSTS
On the 2.7L It has a traditional spin on filter. If you are under the car from the front side; look up at the plastic covering/cowling. You will see an access hole that is about 4 inches in diameter---just bigger than the oil filter diameter itself to give you access to the oil filter. The filter is up inside this access hole by about 6 inches.
If you have the 3.3L, it is a canister type filter. It is located on the top of you engine compartment, under the hood, to the right (Driver Side) of the engine and left of your battery. You need to take off the plastic engine cover (two bolts and four screw nuts) to expose it. It is cylinder in shape with a black plastic cap, which screws off. The filter is in the canister.
Sunday, May 23rd, 2010 AT 12:16 AM
