2004 Hyundai Santa Fe STALL AFTER DRIVING
JLAR
  • 2004 HYUNDAI SANTA FE
  • 4 CYL
  • FWD
  • 72,035 MILES
OUR SANTA FE STALLED ON MY WIFE AFTER DRIVING ABOUT 20 MILES. VEHICLE WOULD NOT RESTART, BUT WOULD CRANK. AFTER ABOUT 30 MIN. THE VEHICLE TURNED OVER AND RAN WHILE SHE WAS WAITING FOR THE TOW SERVICE, ONCE SHE PRESSED THE GAS IT SHUT OFF. I REPLACED THE FUEL PUMP ASSEMBLY, BUT ON THE WAY HOME, I TRAVELED ABOUT 4 MILES AND THE SAME THING HAPPENED. TOTAL LACK OF POWER AND THEN SPUTTERED AND SHUT OFF, WOULD NOT RESTART.
Monday, July 21st, 2008 AT 2:31 PM
KHLOW2008
  • 41,814 POSTS
Hi JLAR,
Thanks for the donation.
You have replaced the fuel pump so we now need to verify if it is mechanical, electrical or fuel pressure that is causing the problem
Was the engine temperature high at the time it happened? Check if the coolant level in the radiator is correct. Hope it is not due to overheating.
Check for sparks at the plugs when cranking.
Spray some starting fluid into the throttle body and crank if it starts, Yes = fuel pressure or injector problem. No = spark problem
Was the Check engine light showing before or when the engine stalled?
Monday, July 21st, 2008 AT 4:55 PM
JLAR
ALREADY CHECKED COOLANT WAS PROPER, THOUGH PROOBLEM ONLY SEEMS TO HAPPEN WHEN ENGINE IS WARM, PREFORMED TUNE UP(PLUGS AND WIRES) @ 60000 MI. SERVICE ENGINE LIGHT DID COME ON WHEN IT SPUTTERED JUST SECONDS BEFORE DYING. CODES WERE P0355 AND P0446 CRANK POSISTION AND EVAP. WAS SUGGESTED TO ME TO REPLACE CRANK SENSOR, BUT THERE ARE APPARENTLY 2, AND WAS TOLD TO REPLACE TIMING BELT AND BALANCE BELT AND WATER PUMP WHILE CHANGING CTP. DEALER WANTS AROUND 1500-2000 DOLLARS. NEED SECOND OPINION AND SOME HELP.
THANKS SOOOO MUCH IN ADVANCE.
JERODE
Tuesday, July 22nd, 2008 AT 7:16 AM
KHLOW2008
  • 41,814 POSTS
Hi JLAR,
There is only one crank sensor, the other is the cam sensor. Electrical and electronic components are unpredictable so if one is faulty replace it. But if it involves doing the same job over again, might as well get it all done up.
The mileage for the timing belt is due so it is advisable for it to be replaced.
The dealer price would be higher but the quality is assured.
Tuesday, July 22nd, 2008 AT 8:07 AM
JLAR
I FULLY UNDERSTAND YOUR REASONING, BUT REALLY DIDN'T REALLY GET YOUR OPINNION. DEALER HASN'T SEEN THE VEHICLE, BUT GAVE THE OPINION IN THE PREVIOUS MESSAGE. WHAT DO YOU THINK?
Tuesday, July 22nd, 2008 AT 8:47 AM
KHLOW2008
  • 41,814 POSTS
Hi JLAR,
Without looking at the car but based on the mileage, I too more or less agree with the timing belt replacement.
The crank sensor code was detected by the ECM so you should get it replaced and worry about the others after you get the car running.
Tuesday, July 22nd, 2008 AT 10:31 AM
JLAR
SO THE CRANKSHAFT POSISTION SONSOR CAN MAKE THE VEHICLE STALL AND NOT RESTART?
Tuesday, July 22nd, 2008 AT 11:40 AM
KHLOW2008
  • 41,814 POSTS
Hi JLAR,
Yes, if it fails, engine would crank but won't fire.
Tuesday, July 22nd, 2008 AT 9:01 PM
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
